07-29-2023 | #1 |
Pressurizing oil procedure ?
My car has been sitting for awhile. I would like to do this prior to starting. Can
Someone point me to instructions for this? TIA, Robin |
07-29-2023 | #2 |
Re: Pressurizing oil procedure ?
what I do on my 1993 ZR1 is remove the fuel pumps fuses ( # 14 and # 15 )
Crank the engine about 3 times ..only cranking for 3 seconds each time ..as to not overheat the starter ....... then I put the fuses in and start the car. works every time and no chain tension-er noise either. Now..this might not be right ....and others may not do it this way..and may have another way but it has worked for me for years Last edited by bob@tradeshowconsulting.c; 07-30-2023 at 08:05 AM. |
07-29-2023 | #3 |
Remove injector 1 and 2 fuses
Disables fuel injectors |
07-29-2023 | #4 |
I believe Marc Haibeck has a tutorial on his website...
http://www.zr1specialist.com/HAT%20W...ping%20LT5.pdf Last edited by AirbusDriver; 07-29-2023 at 08:27 PM. |
07-30-2023 | #5 |
08-07-2023 | #6 |
I don't know if this will help or not, but I enjoy the videos C&S posts and this is one I saw a while back that you might be interested in.
https://www.youtube.com/watch?v=TQgYU0EoZFc The comments section has multiple posts from several folks who have used this successfully to pre-lubricate an engine after it's been sitting for some time. |
08-07-2023 | #7 | |
George. |
