07-27-2015 | #1 |
Corsa X-pipe
I see posts about X pipes all the time but never one for a Corsa system. Does one exist, or system is best with the resonator? I dont mind louder.
07-27-2015 | #2 |
Re: Corsa X-pipe
Corsa does not make an X-pipe. The Corsa resonator is an open design that has no restriction, so replacing it with an X-pipe wouldn't net you any HP.
07-28-2015 | #3 |
Re: Corsa X-pipe
OK, thanks
07-28-2015 | #4 |
Re: Corsa X-pipe
Not being familiar with the Corsa resonator, do you mean to say that BOTH left/right exhaust pipes co-mingle the exhausts within the resonator?? (I was under the impression they remain separate, even w/in the resonator.)
07-28-2015 | #5 |
Re: Corsa X-pipe
I think the Corsa has an H-pipe at the front of the resonator ... no longer have a Corsa system so I can't go look ... maybe someone with Corsa can confirm.
07-28-2015 | #6 | |
Re: Corsa X-pipe
07-28-2015 | #7 |
Re: Corsa X-pipe
I have a custom made stainless steel x pipe. Works great!
1993 ZR-1 #211 Yellow On Beige Beast #2 1992 ZR-1 #427 Black On Black *Sold* 1985 L98 Blue On Blue *Sold* |
07-28-2015 | #8 |
Re: Corsa X-pipe
07-28-2015 | #9 |
Re: Corsa X-pipe
1993 ZR-1 #211 Yellow On Beige Beast #2 1992 ZR-1 #427 Black On Black *Sold* 1985 L98 Blue On Blue *Sold* Last edited by Karl; 07-28-2015 at 02:13 PM. |
07-29-2015 | #10 |
Re: Corsa X-pipe
Prior to building the semi-custom exhaust from the stock system on my 95, I was going to have Dr. Gas build a 2.5 X pipe.
http://www.drgas.com/Tandem-X-Pipe-J...Only_p_52.html Although I opted to go with a Magnaflow Tru-X muffler instead. I would consider calling Scott at Dr. Gas and consult with them or Corsa directly on why they decided to go with H instead of X. Not sure if the secret and patent behind Corsa RSC technology is in the resonators or mufflers. Removing the resonators will probably introduce drone/resonance; maybe there is power to be gained?
