09-21-2013 | #61 | |
Re: Ported Intake for Sale
09-21-2013 | #62 |
Sure will Tom, thanks.
09-21-2013 | #63 |
09-21-2013 | #64 |
I'm learnin' Dom. I'm hoping this pushes me to around 450 hp. I'll dyno it when I'm done.
Dominic, are you tuning for hire? |
09-21-2013 | #65 |
Couple of questions have come up.
Should I have all the mating surfaces machined true? Should I put alignment pins in? Comments from the peanut gallery? |
09-21-2013 | #66 |
You doing just top end? Secondaries? With only top end done, I had 399 to the wheels, so 450chp is very doable. Cams weren't phased.
09-21-2013 | #67 |
Just the top end. Heads and cams will be later, and a tune.
I'm currently 353 at the wheels, so about 415 cshp. |
09-21-2013 | #68 | |
And Mflow cat back.
09-21-2013 | #69 |
OBX headers and exhaust. No cats. Marc chip. K&N. Heavy right foot.
09-22-2013 | #70 | |
The four corner bolt holes of the plenum have been sleeved to tighten up the alignment tolerances - they have almost no slop. I would suggest that you loosely attach the injector housings to the heads, set the plenum on top and run the corner bolts down a bit, then remove the plenum carefully as to not disturb the injector housings and then tighten down the injector housing bolts. This will insure a good alignment and minimize the chance of stripping bolt holes on the injector housings. Once you have the injector housings on and tightened down you can set them up for later if you want by drilling 2 1/8in dowel pin holes per side through the injector housings and heads, you can also do the plenum to injector housings the same way if you like. Here are some pics of what mine looks like.
