04-27-2017 | #11 | |
Re: New ZR1 owner experience.
Got rid of my 2002 busa. I have a road king and my wife rides 884 low. I probably would be dead if I kept the busa. It was like death riding my busa with my wife and her Harley. I gave in for comfort and my life. That busa was insanely fast. I pretty much hit top speed on it on rt91 in Vermont. My buddy was on his Harley going about 80 mph and I went by him like he was going backwards. I hope I don't loose my license driving this z-it is always tempting to drop a gear mash the throttle. I am 48 going on 18. Sent from my iPhone using ZR-1 Net Registry
:Eagle:[URL=http://s653.photobucket.com/user/craigwhite84/media/Kelly%20Boat/IMG_0468a_zpso50qvl1y.jpg.html][IMG]http://i653.photobucket.com/albums/uu256/craigwhite84/Kelly%20Boat/IMG_0468a_zpso50qvl1y.jpg[/IMG][/URL] 1990 ZR1 Black/Black #2317 |
04-27-2017 | #12 |
Yep, banging the 1st 5 gears at redline and letting it pull slow in 6th a blast
04-27-2017 | #13 | |
I would sell this and look for a modified one already done before doing all of the work.
04-28-2017 | #14 |
Check Marc's web site
http://www.zr1specialist.com/HAT%20W...20upgrades.htm He's got a pretty good rundown on what to expect form upgrades. BTW, you get used to the power pretty quick. My car is currently getting top end porting and cams. I hope this is enough, because next is more cubes and I'm hoping not to go down that road. |
04-28-2017 | #15 | |
Top-end porting (limited to the plenum and IHs and some upper - half of the head runners) can be a DIY project, WITH the proper ball gauge(s) and tools. Rear wheel HP can be increased from around 335 stock to 400+ with the addition of headers to augment the porting. Full porting, including the heads, is prolly best left to the experts, as some special runner shape considerations are needed to maximize results w/o breaching either oil or water galleries. And, too, that would be an excellent time to install some of Pete's cams! As such, RWHP would easily be in the 450s - not too bad from a 350 cid motor with good manners!
04-28-2017 | #16 |
Thanks, Paul. I am likely to do just the porting and headers, assuming that cams are going to give me that lopey idle. I want it to sound fairly stock and really don't need or want more power than that would provide. I'm on the east coast, but probably will use Marc.
G
1987 Ferrari Testarossa 1990 Corvette ZR1 1991 BMW E30 M3 1993 Mazda Rx7 3 rotor 2008 Maserati Quatropporte |
04-28-2017 | #17 | |
World Record Run was done in 5th gear with a rear-end ratio change to 3.07 from 3.45.
1990 ZR-1 #1587 1990 ZR-1 #1727 |
04-28-2017 | #18 | |
Just curious as to why it is not recommended . [emoji6] Sent from my LG-H831 using ZR-1 Net Registry mobile app |
04-28-2017 | #19 |
Thanks for the info, but I have made numerous 1.5 mile runs going into to 6th aprox 170MPH, 7K in 5th with 4.10,s, no problem, Bill B ZFDOC magic, car pulled to 181 MPH at 1.5 mile, then drove the car home 7 hours
04-28-2017 | #20 |
I had a different experience on the highway in 6th when transmission grenaded. After a bunch of research and talking to other owners, the advice was the same ...careful with 6th. I'm actually about to install one of Bill Brodreau black tag into my car now, along with new clutch, master, and slave. Hopefully have the same bullet proof reliability some of you guys enjoy.
