Re: A question about the Tech 1 Scanner.
John actually you do. Remember the Tech-1 is from the Atari generation. The brake systems module is a mass storage cartridge. The tech-1 without these cartridges wont know what to to as the cartridges contain the programs. Thats why there are so many cartridges from EEPROM to Body systems, to Chasis systems ETC. |
I do have a used 94 Lateral Accelerator that I got from someone on this net. It came out of an 8,000 mile car. The pendulum is free, so I think it works. My 90 was different, so I could not use this one. Let me know your p/n and I will check it.
I paid $29 for it. |
Im interested if Jeff doesnt want it but im not sure if a 91 one uses the same as a 94. I will reference a few numbers. What part number is it?
There are two numbers on the part: 10143543 and 09401032.
Wont work in a 91 and the mountings a little different :icon_scra |
The TK03030B is specifically identified as "88-93 ABS". I have a TK03030 marked "88-91 Brake". I don't know if TK03030C "88-93 Brake" works for ABS. I think they are specifically marked "ABS" I think you also need a specific ALDL adaptor for doing ABS diagnostics. I am not 100% on any of this, it's just what I understand from reading the Tech 1A manual.
I got the ABS adapter and still got nothing,I give up on this bull$hit.Ill just keep my eye out for somebody else thats having the same problem and learn from that.What have I tried?Paper clip,cheap auto parts scanner,4 high end scanners and finely the Tech 1 scanner.I know if I keep plugging away Ill find the problem,I just thought I might know what the problem is by now.This all started after I replaced the brake pads,I remember I had to force the pads back into the bores of the calipers so maybe I did something.I might check the switch at the M/C.Thanks a to all for the suggestion.
