Re: LT-5 Marine engines
So, GM won't release our dyno sheets, but they allowed Mercury to try to sell the LT-5 to others.
LT-5 came close to being a Bentley engine
That would have been a bummer.
That was post ZR-1
Google Mercury 1350 & 1650 race engine's for (what made me think) newer LT5 based Twin Turbo marine engines.
There was an LT-5 powered boat @ an exotic car dealer in ohio last year. Unsure who made it or who purchased it....
Rick sure has the market cornered on rare LT-5 / mercury items!!!! :cheers: David |
1650 SPECIFICATIONS Crankshaft-rated Horsepower 1650 (1230 kW) Full Throttle RPM Range 6500-6800 Displacement Liter/CID 9.0/552 Bore (in/mm) 4.57/116 Stroke (in/mm) 4.21/107 Compression Ratio 7.8:1 Cylinders V-8 Alternator (amp/watt) 105/1481 Controller PCM distributorless Fuel System Sequential Fuel Injection Fuel Requirements 112 AKI Sunoco Supreme or equivalent race fuel Transmission Mercury Racing dry-sump hydraulic Drive Unit Dry-sump M8 Gear Ratio Application dependent (contact Mercury Racing for additional information) Length (in/mm) 26.69/678 Width (in/mm) 34/864 Height (in/mm) 29/737 (from crankshaft centerline) Weight (lbs/kg) 1720/782 Warranty None* *This product is highly specialized and produced in limited quantities for sale, without warranty, to qualified powerboat racing professionals. |
Here's a picture of its little brother the 1350:
http://www.powerboatnation.com/attac...hp1350_lar.jpg |
Three 1650s (two rights and a left, the middle one running a drive shaft) in a Fountain 39 should be just about right!
FU, do ya think we could lap Long Island in an hour and a half? Stop for lunch at Montauk? |
Miss Geico races the 1650 and will be in key west racing against the turbine boat of Qatar. They already raced in clearwater fl with the turbine boat winning with geico spinning out. Check out Super boat racing website.
Thanks Rob |
