-   -   Important news on LT5 fuel injectors (http://zr1.net/forum/showthread.php?t=24009)
Franke 10-14-2014 10:21 PM
Re: Important news on LT5 fuel injectors
I have them in my 90 for better than 2 years and no problems at all. Thanks FIC.
Blue Flame Restorations 10-14-2014 10:32 PM
FIC, thank you for being there for the Brotherhood!
Agpilot1 10-22-2014 01:08 PM
Going to jump on this deal right now! Thank you FIC!
JimZRyd 10-22-2014 07:20 PM
Originally Posted by Kevin (Post 214029)
Put a set of your new SS ones in a few years ago and love them. Shipping was fast and the product is great.
Do old orders qualify for the warranty or no?
I'm with Kevin...Put in a new set earlier this year. Would it be included in your warranty ?
Dynomite 01-19-2015 02:02 PM
I am assuming these injectors are Ford #19 lb injectors as Brad suggested?
I am also assuming resistance check is around 14 ohms?
What horsepower are they good for in the LT5?
Just guessing here....... :p
I am assuming the Ford #19 are 19 lb injectors rated at a fuel pressure of 39.15 psi.....read that somewhere ;)
If we assume brake specific fuel consumption (bsfc) of .5 lbs of fuel per hour per horsepower.....
Lets assume 400 hp.....and 80% duty cycle and 16 injectors
We would get 15.625 lbs per hr for each injector is required.
If we upped the fuel pressure to 45 psi...we would get a bit over 20 lb per injector available for the Ford #19s which is plenty given the 15 lbs required for 400 hp..... Is this correct?
http://i287.photobucket.com/albums/l...4c95695d29.jpg
http://i287.photobucket.com/albums/l...93bcc1f506.jpg
See Restoration of the Injectors
XfireZ51 01-19-2015 05:01 PM
My question is "Do you provide the Injector Offset based on BATT voltage? Is it the same as stock (which I doubt)?
