Re: Window closes outside weather strip
Im in Fremont,stop by and Ill take a look.
I also used the weather strip adhesive and was able to get the weather strip a bit higher at the end. However, it wasn't even close to having enough clearance. I then compared this window to the passenger's side window and noticed what I think may be the problem. On the passenger side, when the window is up, the glass is evenly spaced across the top under the weather strip. Feeling under the weather strip, there's still some space between the top of the glass and the top of the inside of the weather strip. Between the glass and the pillar, the space is even from top to bottom. Now, on the driver side, there's space between the top of the glass and the top of the weather strip at the front of the window. At the rear (right side) of the window, it's pushing tightly against the inside top of the weather strip. At the rear pillar, there's more space at the top between the glass and the pillar than at the bottom. It's almost like the window is rotated too far counter clockwise. Is there a way to rotate the window slightly clockwise? Here's a picture: http://i34.photobucket.com/albums/d1...psc1a1256a.jpg |
What Jeff said, I will add look in your FSM 10-6-1 thru 10-6-13 before you start, also take a sharpie and outline the bolt heads so you can always move them back in case you adjust the wrong one. Take your time.
So now, I'm trying to fix the things that I'm noticing and hearing. Since I've never driven a pristine Z before, I don't know how it's supposed to feel and sound. So I'm posting them here and working on them one by one. I'm really appreciative of all the knowledge on this forum and everyone's willingness to help. I have not replaced the weather strip. I think they're all original. I don't know if the door panel's been opened before. However, now that you mention it, I do hear a vibration in the driver side door whereas the passenger side is quiet. |
Another thing to keep in mind if the WS was replaced with some of the aftermarket stuff it will cause problems with the window.
