-   C4 ZR-1 Parts For Sale / Wanted (http://zr1.net/forum/forumdisplay.php?f=10)
-   -   ZR-1 Parts:Name Your Part & Price (http://zr1.net/forum/showthread.php?t=29822)
mhobtr 10-22-2018 01:06 PM
Re: ZR-1 Parts:Name Your Part & Price
Originally Posted by -=Jeff=- (Post 285360)
It was removed without tearing it, I know as I was there. But are they different then a narrow body car? Meaning has anyone one here confirmed it?
The slope of the wider body is different at the antenna. A grommet for a regular C4 will not sit flush with the body.
owwdee 10-22-2018 08:17 PM
I need the passenger rear quarter panel if you are able to remove it without damaging it. Shipped to 80022. Not sure how long you’ll have the car. Probably would take a little work to carefully remove it. Let me know. Thanks
Pete 10-22-2018 09:58 PM
George i have none of the above.
Most of the stuff went to the dumpster.
Pete
Originally Posted by George Maz (Post 285346)
-VSS vehicle speed sensor
-Reverse switch plug
...both are small parts from the transmission if you can spare them.
-Will take 4:10 correction gears, blue & white, if present.
-plastic grommet, for drain at fuel fill boot.
-foam doughnuts, from rear hatch pistons.
-rubber grommets, from rear plastic decklid.
-DERM (if no airbag deployment)...would like to give it to member "WVZR1".
-driver side PCV tubes aluminum hardlines tabs intact.
- Horns ...honk honk...lol.
Probably more stuff too, maybe easier if I just take pictures of what I need.
Attachment 8418Attachment 8419Attachment 8420
Sent from my SM-N920V using ZR-1 Net Registry mobile app
Pete 10-22-2018 10:07 PM
I have the wiper motor.
No suspension parts.
No A/C controller.
Let me know what chassis parts you need.
Pete
Originally Posted by TexasZR1 (Post 285265)
I have a black 1990 ZR1 with ~ 53k miles that could use a number of parts.
-wiper motor and control module
-shock actuators and ride control computer?
-AC control unit?
-Misc front / undercarriage parts. The prior owner had an 'encounter' with a curb and went right up over it. There's a lot of parts that got scrapped up. I'll have to send pictures of what I need and see what you have I guess?
Shipping would be to 77084.
Sorry to hear you're having to part it! Care to share the story?
Pete 10-22-2018 10:09 PM
Yes i have them,if your talking about the 2 black bars on each side.
Pete
Originally Posted by S.hafsmo (Post 285350)
Do you have the braces for the rear fender/wheel well (upper+lower)?
Pete 10-22-2018 10:10 PM
It's gone.
Pete
Originally Posted by mhobtr (Post 285354)
If you can get the antenna grommet off without tearing it up, I will buy it.
Pete 10-22-2018 10:15 PM
Hi Dan
Your welcome and thank you too.
I was going to keep the steering column but if you need it i will let it go for $250 complete come pick it up.
Pete
Originally Posted by Flyman 27 (Post 285355)
Picked up my parts Sunday, thanks Pete!
His car still has both rear quarters intact if anyone needs them, they are in very good condition, but you have to be quick, the car will soon be gone.
He also has a steering column with wheel & air bag in good condition. BTW, how much did you want for it?
spork2367 10-23-2018 11:42 AM
I wish I had a way to cheaply/easily get the frame to PA. Let me know if you have any ideas. I'm just too busy with work to drive out.
Pete 10-23-2018 06:38 PM
I'm sorry but had it for too long it had to go.
Pete
TexasZR1 10-23-2018 08:38 PM
2 Attachment(s)
Aluminum parts.
