Re: Frankenplenum
Re: Frankenplenum
These are 222 .415 primary and 236 .425 secondary. The other cams I have are all 236 .425
Re: Frankenplenum
Some Epoxy helps clean up the looks
http://i134.photobucket.com/albums/q...f/DSCN6305.jpg http://i134.photobucket.com/albums/q...f/DSCN6300.jpg |
Re: Frankenplenum
will it fit under the hood or will you need to cut the hood? remember I have one to swap if you are going to cut....
Re: Frankenplenum
Here is a runner inside the plenum; its was mildly ported before; I am opening up the runners completely(This is a work in progress)
before http://i134.photobucket.com/albums/q...f/DSCN6306.jpg After http://i134.photobucket.com/albums/q...f/DSCN6307.jpg |
Re: Frankenplenum
Will this fit under the hood?????????
Re: Frankenplenum
Going to be close, the lid is thicker than my original plan by 1/4 inch
Re: Frankenplenum
Be interesting to see a dyno run after you get this manifold in service....
Good Luck Lee. |
Re: Frankenplenum
Re: Frankenplenum
Going to leave the lid bare...what color should I make the rest of the plenum....I know its lipstick on a pig, but...
Re: Frankenplenum
Why not test it first, then worry about color..
Re: Frankenplenum
Obviously test fit is in the plan.....going on one way or another
Re: Frankenplenum
not Test Fit.. Test it, meaning.. why make it pretty if you put on and it makes the motor run worse.. I suggest test it out for a while first before making it pretty |
Re: Frankenplenum
She is about 1/4 too tall.......will shim the hood
http://i134.photobucket.com/albums/q...ff/LT5tf_1.jpg |
Re: Frankenplenum
just DON'T CUT IT!!!
I am telling you I will swap you if you are going to cut the hood |
Re: Frankenplenum
Runner no longer shrouded....roof of runner raised to reduce curve and 36mm all the way through
http://i134.photobucket.com/albums/q...DSCN6326_1.jpg Lipstick on the pig http://i134.photobucket.com/albums/q...DSCN6317_1.jpg |
Re: Frankenplenum
Re: Frankenplenum
those runners look as if they were sanded smooth prior to the black PC or is the PC really thick to make it smooth?
Re: Frankenplenum
No black gloss really covers well...no sanding
Re: Frankenplenum
Definitely going to need to shim the hood....and even take 1/4 inch out of the center of the plenum cover(its 1/2 thick)
http://i134.photobucket.com/albums/q...f/DSCN6329.jpg |
Re: Frankenplenum
Just dont cut that hood
Re: Frankenplenum
What are you looking to gain with this set-up? Looks very cool :flag:
Re: Frankenplenum
Hoping to see an HP increase, would take 10-15hp...I think opening the inside runners and moving the roof away from the runner will help with flow....but I have been wrong before:)
Re: Frankenplenum
"Frank" is up an running, need some new tires and will then do some testing
Re: Frankenplenum
:dancing
Re: Frankenplenum
Re: Frankenplenum
Yes
Re: Frankenplenum
Re: Frankenplenum
By chance I opened up the oil fill cap and my upper chain guide faceplate has come off and is floating....:censored:
Re: Frankenplenum
When will you go on a dyno? The german racing Team did a 2nd dyno run with impressive numbers.
Re: Frankenplenum
Had Frank out last week.....running good....getting new Toyo Proxes TQs put on this week. Still one small oil leak(,ight be the oil sensor), but its about time to get to the dyno.
Re: Frankenplenum
Re: Frankenplenum
Re: Frankenplenum
Seeing 99/100 KPA readings on my Tech one.....can't wait til tomorrow
Re: Frankenplenum
Re: Frankenplenum
Lee,
Came out looking great. Excited to see the dyno results. |
Re: Frankenplenum
I will be curious to see myself....could be anything from a loss in power to significant gains. Crap shoot....fingers crossed for tomorrow.
I left the Corsa system on for apples to apples test. Next dyno test will be a 3" ....and finally a tune |
Re: Frankenplenum
What was the previous result? Prior to the plenum change?
Re: Frankenplenum
Win some lose some; car lost power....only interesting piece was at 7400rpm the car was only down 8hp from peak.
Frank Set Up 426hp@7100 361 ftlbs Siamase 441hp@7100 373 ftlbs |
Re: Frankenplenum
Car was running pretty fat
11.8 to 12.46 most of the run... 11.8-12.1 from 5100RPM to 6900 |
