Re: 90 ZR1: Oh crud, did I break it?
Alright, now I just need to sift through some existing posts on the best injectors to get. I know better than to start that debate here! :)
OK, I lied. I tried to find the definitive answer but couldn't. I need some advice for good injectors that will withstand ethanol and not break the bank. I found some on Ebay
http://cgi.ebay.com/ebaymotors/1990-...-/310271671038 I'm really not sure what "rebuilt" means in this case, however. Suggestions / recommendations / warnings are appreciated! |
FIC Rebuilds Accel RC Engineering . .. ... Original Multecs from GM (avoid at all costs) Here's a link to Dynomites Solutions page: All the info you'll need. Put on your reading cap. http://www.zr1.net/forum/showthread.php?t=11619 I put Accels in my Z about 3 years go, still working fine. I've read good things about FIC's, definitely the cheapest solution. RC Engineering are pricey but are supposedly the best out there. Stay away from the original Multecs, they were not engineered for fuels with ethanol. They are the most expensive and are absolutely guaranteed to fail. Order up some plenum gaskets from Jerry's Gaskets, his are hands down the best out there and Jerry is really a nice guy. Too bad you're not local, I'd gladly pull your Z into my garage and replace them for you. It's not that difficult, but you do need to pay attention to details. It's very busy under the Plenum, lots of things to mess up if you're not careful. TomC 'Crabs |
So as I understand it, I will need to get these injectors:
http://www.corvetteinjectors.com/sho...p?productid=33 and this gasket kit: http://jerrysgaskets.com/store2/root...roducts_id=459 I guess it could be a lot worse! |
Jon's (FIC) injectors come with Viton o-ring seals already on the injectors. You could save some $'s by buying the gasket/seal kit items separately and omitting PN 17112222-24V.
http://jerrysgaskets.com/store2/root...roducts_id=446 Lube all of the o-rings with a light coat of engine oil before re-installing the injectors. Makes assembly a lot easier and protects the o-rings from damage. No sealant or adhesive required on the plenum gaskets. Clean & degrease the gasket surfaces is all that is required. Lay the gaskets on the injector housings to get them oriented properly, then take the gaskets off and set aside (lay on the windshield is good). When the plenum is ready to be bolted down, raise each side of the plenum just enough to slide the plenum gaskets in place. Hand start all the bolts and tighten in sequence & torque. There are some maintenance items you should perform while the plenum is off. Lots of great pictoral posts available here in the forum. http://www.zr1.net/forum/showthread.php?t=7614 For example; 1. Tighten all injector housing bolts 2. Tighten Crankcase Ventilation (PCV) Box bolts 3. Check secondary vacuum lines for leaks |
Now aren't ya glad ya didn't crank it before pulling the plugs?
And, whata relief! (Not a head gasket, I mean!) You'll want to change oil and filter before venturing out again. I think most of us are following Marc Haibeck's recommendation and using Amsoil AMO 10-40; it has the "right stuff" in it for our flat tappet cams. That #8 plug... I bought a plug socket with the built-in knuckle on top. To that I installed a 2-1/2" extension and taped the two pieces together to keep them from parting when extracting the socket from the plugs. Then, the socket will slip into the #8 and the knuckle allows the extension to follow right in, leaving the end of the extension peeking over the top of the hole when the socket is seated over the plug. I have a swivel-head ratchet that easily slips onto the end of the extension, and after torque is broken, the wrench comes off and I can hand turn the plug out. (Don't forget to put a little anti-seize lube on the plugs before installing them. Ya don't want them to seize and possibly damage the aluminum threads next time you extract them.;)) FWIW, I installed new Accel injectors about a month ago. Oh, what a difference it made...Shweeeeet! Glad you found your gremlin. You can put that behind you for and other dozen years or so!:thumbsup: P. |
Oh, I had an old LT1 Trans Am, but got rid of it before it was close to needing plugs. Yech.
Thanks for all the help and input. Have I mentioned... This board ROCKS! I've ordered some injectors from Jon and some gaskets & O-rings from Jerry. I'll stock up on some oil & filters and we'll get ready to go to town on this bad boy. Hopefully by next week I'll be back kicking some asphalt! |
Glad to hear that things are looking up!
After MANY years following the LT-5, it's AMAZING how many
times the problem is faulty injectors. It seems like this is the weak link! And being underneath the plenum, the trapped heat must add to the stress. I wonder if another design would be better? Hey, how about a carburetor on top of the engine! What a concept! |
