Re: GB: DRM Coilovers
mgg, I have no idea what they were talking about? Do you have a link? I still have the FX3 on the track car and it works perfectly also height adjustment is not an issue at all. You will adjust the coilovers just as you would the non-FX3's. If you are interested in the group purchase just send me your name and what you would like (i.e. coilovers and brackets, just coilovers, just brackets) I'll get your name to DRM and you can place the order through them. Quote:
Did you relocate the upper shock mounting points on the rear? This will keep the shock from coming into contact with the half shaft. Daniel |
http://www.zr1.net/forum/showthread....ight=coilovers |
Daniel
Are the qualities limited? I have another person who doesn't come on the forums who is VERY interested.... Thanks David |
Yes, we are limited on this. Daniel |
GB still open?
If so I'd to sign up. Thank you ry |
The 92 was not upgraded but the 89 is all poly we did that at the same time as the coilover install. Quote:
Daniel dmcguffee@gmail.com |
Daniel |
