Re: Windshield
I'd say it was a wise (Owl) decision rather than a chicken move, Craig. Interestingly, I got a small stone crack (1/4") this morning when I took the Zee for a 20-mile run which included a quick "activate the secondaries" segment which is when I encountered the stone from a semi. I don't have much delam, so I am hoping this does not spread.
Re: Windshield
Re: Windshield
Re: Windshield
What causes delamination?
Why did GM install delaminated windshields? |
Re: Windshield
Poor preparation... Gm also have a similar windshield in a small van around the same time that had no issues.
Re: Windshield
Poor prep? It's a ZR1 ... the flagship American sports car! :censored:
Re: Windshield
Bob, that's normally covered under your Comprehensive insurance (usually low deductible) and my experience (with Met) is that they will send an expert out to look at it and, if not directly in your field of view or causing a big crack already, they will fill it with epoxy for no charge. They use a vacuum device that essentially sucks the epoxy into the chip. If directly in your field of vision or a large crack it will have to be replaced. I had one on my BMW that was to right of center and they filled it and it has been fine. I can still see it from inside but it is not in my normal field of vision driving. --Bob |
Re: Windshield
Re: Windshield
Re: Windshield
Interesting you mention the last ZR-1; I was quite surprised to see the delam on it when I first visited NCM many years ago. With this car having spent its entire life within a climate-controlled environment at NCM, it certainly confirms that environmental conditions (UV rays, etc.) has little or nothing to do with the problem. On a positive note, it does not seem that delamination creeps much over time; at least mine has not noticeably changed in a decade. Bob |
