Compression Test
I borrowed a Snap-on Compression Test kit from a buddy. It has
(4) different 8" long hard rubber hoses with one end threaded for the spark plug hole and the other end an air compression fitting for the gauge. The threaded end has a thick rubber washer, but with our deep- sunk spark plug seats there is no way to get in there and tighten the hose down. Is finger tight OK? I also saw you can get rigid extentions. Is this what you guys use? Thanks, Ted |
Re: Compression Test
Thanks Jeff & Dyno.
We need to get some sleep. |
Finger tight is fine and flexible rubber extensions are fine :cheers: http://i287.photobucket.com/albums/l...sionTester.jpg See Item #4 LT5 Final Inspection including Brake Tricks Compression tests |
