-   -   Looking for a quality, non fitted cover (http://zr1.net/forum/showthread.php?t=26279)
Kevin 03-29-2016 01:25 PM
I don't drive my Z as much as I should, yeah I know it's my fault, but when I'm not driving it I'd like to keep it covered without having to fight with the fitted cover I have now. Does anyone know of a non-fitted cover that's not a bed sheet out there for our cars?
BigJohn 03-29-2016 01:58 PM
Re: Looking for a quality, non fitted cover
A good C5 cover would work fine; that is what I use.
Kevin 03-30-2016 03:38 PM
Never thought of that john, thanks
Mystic ZR-1 03-30-2016 04:41 PM
Is the car garaged?
If not, a fitted one is better for outside use.
Might be a little harder to put on, but better
in the wind etc.
And John, keeps the pine needles out too... :-D
Kevin 03-30-2016 06:34 PM
Originally Posted by Mystic ZR-1 (Post 240218)
Is the car garaged?
in the wind etc.
the car is garaged. I just need to keep just and other crap off the car while it's parked during the week
BigJohn 03-30-2016 06:59 PM
Is the car garaged?
in the wind etc.
The pine needles get everywhere!
Heck I have had them in my underwear!
KILLSHOTS 03-30-2016 07:48 PM
Not sure if you've ever considered this, but I've found that most folks have serious misconceptions about covers being "protective". If you care about your car's finish, then the only time a cover should be used is immediately after the car has been thoroughly cleaned. And if the cover is ever used on an even slightly dusty car, then the cover should be thoroughly cleaned before being used again. Why? Ask yourself, would you wipe your dusty or dirty car with a dry towel? If you did, you'd just be grinding microscopic rocks into your paint. Stretching a cover over a dusty car is the same thing. Unless used properly, covers hurt your finish, and this is especially dangerous for dark colors. Just food for thought; unless you want to clean the car every week immediately before garaging and covering it, you may be doing yourself more harm than good.
