Massive Oil Leak from Oil Cooler Lines
Good evening all,
My project stalled for awhile but I have finally got the itch to get this car moving again. I went to start it the other day and when I did, I noticed a huge leak from what appears to be the oil cooler lines where they attach to the block. I plan on selling this car, but what is the best 'proper' way to fix it? https://uploads.tapatalk-cdn.com/201...38193c781f.jpg Attached is a picture of where I believe it is leaking from. Thank you in advance! Tony Sent from my iPhone using ZR-1 Net Registry |
Re: Massive Oil Leak from Oil Cooler Lines
common failure...just replace them before it makes a huge mess.
Choice of Black Braided or SS Braided. Same pressure rating. We sell about 5:3 black vs SS. Made in house with Edelbrock-Russell components & pressure tested.
http://www.jerrysgaskets.com/hose-se...ess-90-95-1f2/ or http://www.jerrysgaskets.com/hose-se...ck-90-95-10c2/ |
Thank you, I just ordered the stainless set.......can't wait to put them on!
Finally got them on which fixed the leak but more problems I will post about later...
