-   -   Brake ducting? (http://zr1.net/forum/showthread.php?t=3430)
va beach biker 05-29-2007 09:25 PM
Brake ducting?
Anyone by chance install Mid America's front airdam with the attached brake cooling ducts? I need to replace mine soon, and adding the duct work at the same time seems like a easy mod.
tccrab 05-29-2007 10:14 PM
Re: Brake ducting?
Check out Frank's 1991, he's put ducting on his.
http://www.zr1netregistry.com/forum/...ead.php?t=3352
I don't know if it's Mid Americas or not, but it looks pretty straightforward.
You might ask him a few questions, but be forewarned, English is a second language for him (He's a Barcelona Spain native) so make it as easy to understand as possible. He's a very bright and nice guy, but sometimes the language barrier is pretty tall... ;)
UKZR1 05-31-2007 06:40 PM
Re: Brake ducting?
I've fitted the MidAmerica kit. Its ok. Needed some 'modding' to fit right but now its on ok. I also fitted aluminium mesh into the ducts to improve the looks
mrzzzr1 06-04-2007 03:22 AM
Re: Brake ducting?
Did the brake ducting eliminate any brake problems?
UKZR1 06-10-2007 04:39 PM
Re: Brake ducting?
Only time I had the Movits very hot was when I was forced to slam them on at 180 on an autobahn to avoid a car that pulled out infront of me;) I needed to replace that part anyway so went with the coolers
mrzzzr1 06-18-2007 12:46 AM
Re: Brake ducting?
A 180 mph brake slam would be a major test of any braking system on any car I would presume.
