WTB: 1990 ZR-1 ECM
I am in need of an ECM part number 1228331 for my 1990 ZR1. If you have any knowledge of where I can obtain one please let me know.
Re: 1990 ZR1 ECM Needed
I might have one
Rocky,
I came across this company that repairs ECM's. ModuleExprets in Jacksonville Fl. Their number is 888-593-2262. See if they can help you. John |
Thank you for the info!
yeah let us know what they charging
And what is your car doing that you think the ECM is the problem? |
It has an intermittent misfire. It runs great and then it loses a cylinder. I replaced the ignition module first and all injectors plugs and wires. Still did it, so I pulled the ECM and had it run in another ZR1 with no problems and it duplicated the misfire after about 10 mins of running. Sure hope this is the problem.
I had a very sililar problem some years ago. In my case it was caused by me back probing the injector pins at the ECM plug. Big no no.
https://zr1.net/forum/showthread.php?t=10828 Hope this helps. |
Re: WTB: 1990 ZR-1 ECM
FL? If so, could you update us on what they said? |
