Starter Interrupt relay
I've been going back and forth with this issue with my 93 ZR-1. When the starter interrupt relay gets hot, I can't start the engine. Does anyone have the GM part number for the relay and do they still make them? I called a bunch of automotive stores and they don't have any in stock.
Roy |
Re: Starter Interrupt relay
Where is it located on the car? You have a part number?
I don't have a part number. That's what I'm trying to find out. It located behind the driver side dash panel. It's a pain to replace.
Roy |
IS this the one that is listed in the FSM as Starter Enable Relay? (Page 8A-201-9, Figure 24 of the 1990 FSM)
I want to confirm before giving you bad info |
here is the replacement relay for the Starter Enable.. That should help you chase down OEM
https://www.rockauto.com/en/moreinfo...8E8dGtog%3D%3D |
My car is a 93 ZR-1 and it is different than the 1990 ZR-1. The relay is on page 8C-28 and is diagram 32. I looked online at Rock Auto and the part that you mentioned is different than what I see. Thanks for the help.
Roy |
Probably a smaller form factor. I don't have a 93 FSM so I can't check it out
4 Attachment(s)
I had a quick look in the Corvette Part books. I have two versions :
- a PDF one which covers 1984 to 1996 (quite old) - A printed version which covers 1984 to 1993 (got it 2 years ago, recently printed). In the PDF (1984 - 1996) : The official part number seems to be : GM 14100455 or AC-DELCO #15-8426 which is a 5 pins relay. In the book, they group all the Instrument Panel relay under a single schematic number (31). I guess that was easier than drawing every single relays. In the printed book (1984 - 1993) I get : GM 25520198. This is also a 5 pin relay. |
