Haibeck Engine Upgrade
Is there anyone on the forum that has bought Marc Haibeck's 500Hp engine package who could talk a little about the before and after results?
Are you satisfied or are you sorry you didn't go for one of his larger displacement packages? Thanks. |
Re: Haibeck Engine Upgrade
Thanks brazilfree. Why didn't you have Marc dyno it?
Do you know if there was anything in your current Lingenfelter build that is not a part of Marc's 500Hp package? |
Also generally speaking, and you probably already know this. But I would guess his 500 package makes less difference on a car that already has port work done than on a stock '90-92. Unless you have some kind of freak, or I have some kind of whatever the opposite of freak is, your car is a lot stouter than a stock one. It sure felt stouter than my car with the top end done. |
Well...Demps yellow car is a tribute to Marc's work. He ran 168 in the mile at Nellis AFB last fall with just top end work done on his car. Marc and Ted were both proud of it...and rightly so. It was impressive...he was right up there with a fast 368 and almost with the 415 cars. Very Impressive. Marc's work is tops. Maybe that's why he only works on ZR-1s and he makes a decent living at it. Everyone knows his work. He's also working on FU's oil change...and has been for QUITE SOME TIME!
I definitely would have had marc dyno/tune that bad boy if it were me
Marc, has never done any work for me personally, but I have met theman a few times, seems like a great guy BUT MOST IMPORTANT he shows up to most of the registry club events and SUPPORTS his work, that is worth a WHOLE LOT IMO.
Marc did the work on my yellow car. It is a horse! I'm not the best driver in the world but the car ran an impressive 168 at Vegas. Marc's car ran a 161, if I remember correctly. In comparison, LocoBob's 368 ran a 171 in Vegas and it dyno'd on the top side of 480 rwhp. My car is lowered with coilovers which helps but it also ran a 12.21 (2.1 60' time) at 119.95 at a 2,700' elevation track. Marc does tremendous work.
Most 350 packages nowadays are only top end. LPE in the day did use Oliver rods plus raised the compression to a 12:1. The cars have a tremendous low end pull. The few I've seen dyno'd around 410 rwhp but like I said have a stout low end. I would not hesitate to have Marc Haibeck work on my car. Not only does he do great work, he is a standup guy with an incredible attention to detail. Ted |
This is another Ted who highly recommends Marc!
Not only does he do great work, but Marc has spent much of his time helping me with advice and recommendations and to answer all my questions. I have my close circle of people I trust for my Z and Marc is one of them! Ted Feder |
