Can someone ID this connector>>>
Re: Can someone ID this connector>>>
Diagnostic link for when the car was going down the assembly line.
Thanks...makes sense...a pre OBD II type port?
M |
It doesnt do anything its function is just what jeff said.
When I've had my car dyno'd, the tach signal was picked up there. And I used the ground from it when checking injector resistance through the ECM harness. |
I mean that actual conector the one that plugs into that harness right there does nothing it is a dummy conector. |
Technically it is called the "Electronic Ignition Diagnostic Connector".
It's labeled as G|F|E|C|B|A G - Goes to coilpack base F - Tach out E - Bypass Input C - Ignition Control Input B - Reference Lo A - Reference Hi The ALDL is located beneath the drivers side hush panel. |
Thanks all...more info for the library!
Michael |
