Air Intake Emissions Blower FOAM Filter ????
If you are sitting in the ZR-1, in the front nose area directly to the left of the air filter cover is a small Foam Filter. I want to know what it is actually called & where I can get a replacement. Mine is falling apart from age. I was told it has to do with the Air Intake Emissions Blower & only comes on when you crank the " BEAST? HELP !!!!!
That may be part number 14104698.Look in the members only section and contact Pete. He can help you out.
