-   -   Brakes (http://zr1.net/forum/showthread.php?t=7493)
Bob G 01-10-2009 11:56 AM
Brakes
I am thinking of buying Wilwood SL6R Front brake kit. superlite 6 piston billet calipers ,Alum. Hats with 13 in. rotors does any one have this set up on there car? How do you like Them? How Good Are They?
Thanks Bob G.
Zr1 Destroyer 01-10-2009 01:29 PM
Re: Brakes
They work nice and I get plenty of complimants on them! A quility upgrade for sure, but I have to run a 3/8" spacer when I bolt up the sixteens for the track.
Bob G 01-10-2009 02:16 PM
Re: Brakes
Do You Have Any Pics what Color are your Calipers ??
Bob
ZZZZZR1 01-10-2009 03:51 PM
Re: Brakes
Thanks Bob G.
That's a great brake upgrade....
I like the C6 brake upgrade and you can have it done right for "cheap".
Powdercoat them and get the brackets from Jeff F.
http://i160.photobucket.com/albums/t...l/C6brakes.jpg
ZR1Vette 01-10-2009 04:57 PM
Re: Brakes
Just in case anyone wants to see a Z51 brake set on a C6 with powder coat calipers/brackets/pad backing plates (which is what you can do if you want for a ZR-1) here is my set up on my C6>> NOTE: I am a 'contrarian' and decided on satin black finish instead the more common often used red or yellow or blue..but all is matter of subjective taste
http://i17.photobucket.com/albums/b7...rakedetail.jpg
http://i17.photobucket.com/albums/b7...ontbrakeSS.jpg
http://i17.photobucket.com/albums/b7...frntwheels.jpg
RICKYRJ1 01-10-2009 05:56 PM
Re: Brakes
I have the C6 Z51 brake set-up on my 95, picked it up from Jeff F. Red PC cals. w/Baer 2 peice rotors. Works great and looks good doing it. :mrgreen:
USAFPILOT 01-10-2009 10:26 PM
Re: Brakes
Will C6 Z51 brakes fit under the stock A-Molds
ZZZZZR1 01-10-2009 10:30 PM
Re: Brakes
Yes 100%
EDIT! Thanks Jeff, didn't notice the Z51! Stock C5 / C6 no problemo
Jeffvette 01-10-2009 10:33 PM
Re: Brakes
No.
The C6 Z51 uses a 13.4" rotor. You can get it inside the barrel, but you leave no margin for error. No wheel weights, no caliper flex, no debris and no room for heat ventilation.
You can use the C6 caliper with a "base" C6 rotor or a C5 rotor.
TFENT 01-10-2009 11:00 PM
Re: Brakes
Originally Posted by Jeffvette (Post 51913)
No.
Jeff:
what are the base C6 and C5 rotor dimensions? Is there a write up on what brake upgrades can be done and a parts list? What about rear upgrades, other then to a BBK?
