01-03-2014 | #1 |
Question on ultra low mile ZR1s
Hey Guys,
New to to the forum, and looking to purchase my first ZR1/Vette. What are your thoughts on buying a ZR1 with less than 1000 miles? Safe to assume there may have been years where the car didnt run - do you see issues with seals, gaskets, bushings, etc. drying out, cracking? Any sense of what kind of work would need to be done to get one of these roadworthy? Thanks, Mike |
01-03-2014 | #2 |
Re: Question on ultra low mile ZR1s
money...lots of money. for the premium a no mile car will bring you're better off getting a higher mile car and driving that and saving the rest for repairs
01-03-2014 | #3 | |
Less than 1,000 miles will be way Over Priced as a collector ZR-1 if you are looking for reliability/driving fun. Exactly as you say....maybe some of the normal issues which are age related having nothing to do with driving. The best mileage I have found is between 50K and say 75K miles. You should have someone knowledgeable check anything you are considering buying first just as a precaution. But on the other hand........You apparently plan on driving (roadworthy) a ZR1 with less than 1,000 miles on it which is fine and the kicks you get out of driving an essentially show room ZR1 might be worth it to you. Again.....change the fluids and if no check engine lights and no misses at any speed........and if the vacuum pump shuts off within a few seconds with key on......go for it I think what everyone will suggest is that the value of the ZR1 drops quickly as you add miles beyond a very low mileage ZR1 to say 30,000 miles more or less. But the value of the fun driving a showroom ZR1 may be worth it as that is no different than say buying a showroom any model in essentially new condition. The most important test I do up front is a compression test after that just pull the plenum and eliminate TB coolant and recondition everything under the plenum (secondaries, injectors, starter, coils) and you will have a very reliable driver no matter the original miles. Seals unlikely, gaskets unlikely, bushings and tires hardened but not worn......If there is a check engine light or a miss at any speed or if the vacuum pump does not shut off within a few seconds with key on.........Probably pull plenum and recondition/replace injectors, change Engine oil, Transmission oil, and Differential oil as well as make sure you have green antifreeze 1825M GM Spec. LT5/ZR-1 Fluids
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 01-06-2014 at 09:50 AM. |
01-03-2014 | #4 |
A ZR-1 with <1000 miles is a museum/collector piece. If you want to buy a ZR-1 to drive, and you have a budget to buy a collector car, buy a low mile (10,000-30,000 mile) 95 ZR-1.
If you are thinking that you should buy this ultra low mile car, put it in your collection and don't worry about driving it.
Dennis Fierstein 90 ZR-1 #2562 Atomic-Z ZR-1 Net Registry Chairman of the Board ZR-1 Net Registry Treasurer Last edited by A1990; 01-04-2014 at 02:20 AM. |
01-03-2014 | #5 | |
Dennis just nailed it. If this is a buy for the low miles to keep in a collection then doing a few things (fluids, plugs etc) would be it. As it sits with that kind of mileage that would be the best thing. Low mileage cars get more rare all the time. A low mileage car is very unlikely to have engine damage. If you intend to drive the car and want it to remain worth max $ (should you want to sell it later) then I would not do mods that are hard to undo. It's rare that a heavily modified and customed ZR-1 will retain it's value well. (that must be clarified to be obviously my opinion) If max speed and performance is the goal and resale value is of no or less concern then get out your check book and have fun. The $ is the lesser concern. In any case weigh carefully any advice you get to modify the car until you fully get the pros and cons. Most ZR-1s out there, being as old as they are now, have been maintained and those that have been ripped up will be fairly easy to spot. Good luck with which ever car you pick.
Scott Vett owner since 1979._It's about the car and the people Last edited by scottfab; 01-06-2014 at 09:24 PM. |
01-03-2014 | #6 | |
Just for reference - I got mine with 17k miles on it and I have dropped about $4k on it already. Had Marc Haibeck do injectors, coils, coolant flush and remove radiator and clean it, + his chip. I have also gotten the A/C switched over to R134, had an issue with a brakelight switch, and have replaced any interior pieces that were cracked. I have a set of '95 Sport seats and stuff to put them in sitting in garage right now ( if you are a bigger guy the 90-93 Sport seats might not be too comfy - I'm 6'1" 225) And I still have to drop another $1k on a set of tires (long story) SO - if you want a DRIVER - get one that has had all the stuff done to it already and DRIVE it. If you want a collector - pay the $ and let er sit... JMO
[LEFT][SIGPIC][/SIGPIC][/LEFT] [CENTER][COLOR=Indigo][SIZE=4][I][B] **Now Sold** 1990 ZR-1 #2093, Black on Black..[/B][/I][/SIZE][/COLOR][/CENTER] |
01-03-2014 | #7 |
i purchase a low mile 1995 red z back in september
the car had a little over 2,400 miles the owner stated that over the years he did drive it around the neiborhood and open it up a little for maintenance before buying it i took it for a test ride check all options and the only thing i found wrong was a leaky clutch slave cylinder which i had rebuilt by power torque (excellant service ) since then i have driven the car on 3 short drives totaling 100 miles and so far so good i do know that it is a 19 years old that is near brand new and there will be a few small issues from time to time ( now that i jinxed myself) but for me i enjoy the fact that the condition of the car is perfect ( paint , interior, weatherstrip etc.) and i know the history of it. buy what you like ... be happy with your purchase... and do with it what you want life is short |
01-03-2014 | #8 |
I had a chance to buy a 14k car for only a few $C more than the 32k car that I ended up getting. Only if the 14k car been a few $C CHEAPER, would I have considered it, all else being equal...........
I'm getting my snappics / threads removed blindly as fast as I can, to get in compliance with copyright / license TOS on the boards here (lots of FSM pages and other copyright / license violations on my part; sorry guys). And thanks to all the guys who didn't whine when I posted those FSM copyrighted / licensed stuff in my threads... ( :thumbsup: [b]and to think I complied with a mod's request to delete a pic of him in a Challenge Car in NCM Museum, so he wouldn't get in hot water)[/b] Thanks to several guys here for sending parts FREE; BearlyFlying, WeGone, Geezer, GoldCylon, and more there, TonyD, mike100, fletchusmc... 1990 #2794; 4L60e Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless, Power Effects 3" [IMG]https://lh5.googleusercontent.com/-GHpfzty7DVU/UQn-0Ru2xAI/AAAAAAAAA14/08mz1p4QLD4/s445/Screenshot-5.png[/IMG] |
01-03-2014 | #9 | |
Many of us here modify our ZR-1's and enjoy them just as many here enjoy their completely stock ZR-1's. And if your preference is a 100% stock ZR-1, you're in the right place to keep it maintained that way. This is a great place to be if you love the ZR-1! Long live the ZR-1. Brett Henderson
1988 KOH Prototype EX5023 sold 1990 ZR-1 #444 Convertible 1990 ZR-1 Black #966 1991 ZR-1 Quazar Blue #296 1957 Duntov SS Project Last edited by Blue Flame Restorations; 01-06-2014 at 12:43 PM. |
01-03-2014 | #10 | |
Having Fun Modifying the ZR-1
Concur Completely and I have no clue and have not seen a ripped up ZR-1 or ripped up LT5 There were NO modifications that cannot be reversed. There was nothing against (Cons) any of the Modifications. All Modifications improved performance, reliability, and value of the LT5s, L98 and ZR-1s. My ZR-1s and Corvette (L98) all run perfectly and are modified/improved each differently (a 90', 91', and a 90') See......... LT5 Eliminated Systems Marc Haibeck on LT5 Eliminated Secondaries LT5 Added Systems 90' LT5 91' LT5 90' L98
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 01-05-2014 at 09:20 PM. |
