![]() ![]() Join Date: Aug 2005
I borrowed a Snap-on Compression Test kit from a buddy. It has
(4) different 8" long hard rubber hoses with one end threaded for the spark plug hole and the other end an air compression fitting for the gauge. The threaded end has a thick rubber washer, but with our deep- sunk spark plug seats there is no way to get in there and tighten the hose down. Is finger tight OK? I also saw you can get rigid extentions. Is this what you guys use? Thanks, Ted Last edited by tf95ZR1; 11-01-2015 at 12:34 AM. Reason: Wanted 2 |
Thanks Jeff & Dyno.
We need to get some sleep. |
Speak for yourselves
![]() Finger tight is fine and flexible rubber extensions are fine ![]() ![]() See Item #4 LT5 Final Inspection including Brake Tricks Compression tests
