Old 03-04-2016   #1
Leempoels
Leempoels's Avatar
Default Easy installation of LT5 Serpentine Belt
An effortless installation of the OEM GM 10067477 / 6PK2037 Serpentine Belt on the LT5
Remove air duct.
With the tensioner rotated, route the belt around the pulleys having it first behind the water pump pulley on the driver side. Then pass a thin nylon rope behind the belt between the generator pulley and the water pump pulley. Pull both ends of the rope from the driver side around the water pump pulley, the belt will easily go around that pulley. Remove the rope and release the tensioner.
Leempoels is offline   Reply With Quote
