Operational Engine Stand Set Up Complete
This be my next project to set up an Operational Engine like the guy on Ebay. ...........found this on Ebay for sale and seemed reasonable with only 23,000 miles on Engine/Trans. ![]() ![]() ![]() ![]() ![]() ![]() Operational Engine Stand
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 02-17-2017 at 10:19 PM. |
![]() Join Date: Nov 2011
Aaaaaand, what are you going to with that?
![]() Join Date: Feb 2013
Good Question
![]() I just never seen an engine for sale ready to fire up on the pallet you receive it on (with Oil Cooler and engine gauges Installed). Including complete wire harness and gauges installed (all you have to do is add Engine and Trans Oil). I will add Radiator and functional 1990 drivers seat and air cleaner ![]() I will not include the steering wheel as shown unless I do want to make a Soap Box Derby Racer ![]() Test Stand..... ECMs, Radiators, Oil Coolers, Thermostats, O2 Sensors; All Engine Sensors which are now easy to get at, Clutch Components, Gauges including, .....Engine Oil Pressure, .....Tachometer, .....Alternator, .....Oil Temperature, .....Coolant Temperature, I cannot figure out why he has the steering wheel and the full size fuel tank? He does not include a radiator or mufflers but does include a functional thermostat (at least until the thermostat opens at 180 deg F). Looks like a clutch pedal and Brake pedal and throttle.....not sure why a brake?
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 02-18-2017 at 09:13 AM. |
#5 | ||||||
![]() Join Date: Dec 2003
![]() Im still trying to figure out how that whole apparatus is going to ship ![]()
Would probably have to go freight on a semi-truck trailer. You'd probably have to have a forklift on site at delivery to get it off the trailer. Someone with a large enough flat bed or enclosed trailer might be able to do it, but that pallet looks pretty damn wide.
![]() Join Date: Jan 2010
Looks like all it needs is wheels.
Could simplify delivery? |
![]() Join Date: Aug 2016
There are no mounts holding the engine or transmission. Would be 1/4 that size if it were on a welded frame on wheels.. why all the controls? Is someone jerking our chains? A mad scientist perhaps.
#10 |
![]() Join Date: Nov 2016
I feel bad for the donor car.....
Bill Schroeder Texas Proud! 1991 Corvette ZR1 #1388 2015 Challenger Scat Pack Shaker [SIGPIC][/SIGPIC] |
