Old 01-07-2018   #1
gtcollins@maxnet.co.nz
gtcollins@maxnet.co.nz's Avatar
Default Went to the track
Hi all hope your winter isn't treating you all to badly we are enjoying summer over here in New Zealand
I went to my local drag strip and raced my ZR-1 for the first time since getting it going again after my engine failed I got a best time of 12.68 @ 113.25 MPH I haven't tuned the engine yet a good start I think I would like to see if I can a 12.3 one day
Regards Glen
Sent from my SM-G930F using Tapatalk
gtcollins@maxnet.co.nz is offline   Reply With Quote
Old 01-07-2018   #2
Default Re: Went to the track
THAT is some good drivin'!
I've seen 12.3s done, and my best was a 12.4. But, those cars had been ported with free flowing exhaust and dyno around 430 SAE rwhp HP and going through the trap at 120-121 mph. So, a tune may help a little, but my experience is that a few more HP is going to help a lot in getting to 12.3s.
It's about -18C outside as I type this. We're all envying you right now! Thanks for posting. We (I) needed that!
Old 01-07-2018   #3
1LEZ
Nice job!
1LEZ is offline   Reply With Quote
Old 01-07-2018   #4
RichS
Nice, What was your 60'? Getting that lower will help get your times down.
RichS is offline   Reply With Quote
Old 01-07-2018   #5
Hi Paul -18c that's real cooled where I live the coldest ever recorded weather was 4.1 I have lived in the same city all my life and we get snow sometimes on the hills in the winter it may stay a day or two we did get snow on the valley floor once where I live it was a great delight for all a once in a lifetime experience.
I have headers (which I made )and a 3"exhaust jerry's twin plate clutch I have ported the injector housing a little I haven't completely removed the injector bosses I also have a Marc Haibeck chip I fitted Doug Rippe brackets to the rear suspension and urethane suspension bushes I am also running Hoosier drag radial I am hoping to go racing again at a different track
Old 01-07-2018   #6
Originally Posted by 1LEZ View Post
Nice job!
Thanks
Old 01-07-2018   #7
Hi my best 60' was1.906 and when I run the 12.68 my 60' was 1.931
Old 01-25-2018   #8
Bob Eyres
You didn’t say what gears you were running.
Your engine is strong for being almost stock, most stock motor ZR-1’s trap at about 110mph.
4.10 gears will give a solid improvement in 60ft. Times.
4.10’s and drag radials gave me a best 60ft. Of 1.76, and a best e.t. of 12.06 @ 117mph, with a stock engine, headers, 3” exhaust, single mass flywheel.
Stock motor cars (especially the 405hp. version),are actually capable of high elevens with lots of external bolt-ons, and cool air.
For the first time out, you’re doing great, Glen. Keep it up!
flywheel
Old 01-26-2018   #9
Hi thanks for the encouragement ZR-1 is running stock 3.54 gears I went to a different track this time (Masterton Motorplex is the close track )Meremere drag way 6hrs from home so I was running on my road tyres that came with the car sumitomo's my first run was 12.924 @ 112.42mph with a R/T of.186
Second run was12.926 @112.46mph with a R/T of.167
Third run was 13.081mph @ 113.18 with .254 R/T
Fourth run was in 13.008 @112.80mph with a .239 R/T
Last two race had bad R/Ts so will have to work on my R/Ts the car is running good and consistent with .157 difference in time's just let myself self down with my reaction time's I am going back to Meremere next weekend if the weather is good and will see how we go
Regards Glen
Old 01-27-2018   #10
Bob Eyres
I wouldn’t worry about reaction time at this point, ( I go on when I see the last yellow light up, but yours will vary.)
That 60ft. Time is the big deal. Every .10 drop in the 60ft. Means multiple car lengths at the other end. Good luck
