Old 01-29-2018   #1
conesare2seconds
Default DNS dreaded no start - low voltage edition
Hi everyone. My 94 has an intermittent no start condition. Always starts with a jump.
When it won’t start, the voltage meter is inevitably low, below 13 volts. The battery was new in May and I just replaced the alternator. The security light does not blink when the car won’t start. The volt meter does not dip when you try to crank the engine over.
I’d be grateful from any suggestions.
Old 01-29-2018   #2
Default Re: DNS dreaded no start - low voltage edition
Recondition the starter Solenoid points
Starter, Starter Relay, Wiring Harness, Battery, and Plugs Tricks
Old 01-30-2018   #3
conesare2seconds
Makes sense. Appreciate the tip.
