Go Back   ZR-1 Net Registry Forums > C4 ZR-1 > Cleaning and Waxing
Old 09-25-2017   #1
Jim Stanley
Default Engine Polish
So, I cleaned the gray painted parts of my engine with Arm & Hammer Extreme White toothpaste as recommended by one of the posts. It cleaned well, but now I have a more matte type of finish. What would be the best thing to use to shine it up a bit.
Thanks!
Jim Stanley is offline   Reply With Quote
Old 09-26-2017   #2
lfalzarano
Default Re: Engine Polish
Try a non-wax polish. Wax will yellow from the heat.
Lou[COLOR="Red"][B][SIZE="4"][/SIZE][/B][/COLOR]
Old 09-26-2017   #3
Jim Stanley
Good to know, thanks!
Old 09-26-2017   #4
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
Meguiers Nex Tech Wax (it's not wax)
Marty
Old 10-10-2017   #5
Jim Stanley
Marty
Thanks Marty, I used it on the plenum and valve covers and it shined them up and did not yellow under heat.
Sent from my iPad using ZR-1 Net Registry
Old 10-14-2017   #6
DRM500RUBYZR-1
Glad to hear that it did the trick for you!
Re-apply 1 or 2 times per year minimum in order to keep the shine and avoid having to polish it again. Much easier using this method than the mess of polishing it with toothpaste or another abrasive.
Now go drive it and get it a little dirty!!!
Marty
Old 10-14-2017   #7
lfalzarano
I use the same routine. Best shine.
Old 10-20-2017   #8
Mr Blue
I have used Color Back Finish Restorer with good results. I removed the oil stains and did not appreciable diminish the color or luster.
Mr Blue is offline   Reply With Quote
Old 01-25-2018   #9
berthaknight
Yes, I think that you should not polish your engine! At least, I would be afraid of doing so... The polish somehow may damage its surface!
[url]http://edit-it.org/blog/choose-the-best-proofreader-online-with-our-editing-service[/url]
berthaknight is offline   Reply With Quote
Old 09-08-2018   #10
Crusin
Crusin's Avatar
Good advice Marty. I knew that wax would yellow from the heat but wasn't aware of the Meguiers Nex Tech wax. I will give it a try as my plenum is clean but has little shine.
Crusin is offline   Reply With Quote
