Old 05-10-2007   #1
zr-1assassin
zr-1assassin's Avatar
Default GETTING A WHINING IN REVERSE???
I am getting a bit of a whining noise in reverse after i first start the z. its when i press or let out the clutch!any ideas on this?? its only reverse that i have noticed it in. had the clutch replaced a few months ago with no problems. any ideas here?? (it sound just like keith during anal sex )
zr-1assassin is offline   Reply With Quote
Old 05-11-2007   #2
blackjack
Default Re: GETTING A WHINING IN REVERSE???
i dont know about the zf trans,but most manual trans have straight-cut gears in reverse,hence the whining...i suspect the zf is no exception...
bj
blackjack is offline   Reply With Quote
Old 05-11-2007   #3
GrayZ
Cool Re: GETTING A WHINING IN REVERSE???
you are a dirty minded young man. You've been hangin out with that
other boy, with the mousse in his hair, too much.
you want a little cheese with that whine??
Old 05-11-2007   #4
zr-1assassin
your an edjamacated man on the Z, what do you think it could be keithy?
Old 05-11-2007   #5
GrayZ
chris...i think they all make a small whining sound, in reverse, mine does.
as long as there is not a clunk or grating sound, i think you are ok.
maybe one of the qualified mechanics will jump in here.
I'm not. although i did stay in a holiday inn select last night.
Old 05-11-2007   #6
Is you wife or girl friend with you? My whines a little too I think its normal
Old 05-11-2007   #7
zr-1assassin
update!!!! it now seems to be doing it in neutral also. i thought it was reverse because i always back the car out of the garage when i first start it, but it seems now to have nothing to do with reverse. its just when i press and let up on the clutch, but it only will do this for about the first 30sec or so and then it stops. as if all the clutch fluid has drained out after sitting and then needs a few seconds to build back up after start???? this only does it after sitting over night or for a longer period. anyone have any ideas on this?
Old 05-11-2007   #8
jonszr1
jonszr1's Avatar
don,t mean to be a smart a## but did you ck fluid levels of both the clutch and trans. mine did this whenthe level in the trans was high. you know raise just the front squirt in fluid and too full cAUSE MY LAZY BUTT didn't want to raise the whole car
Old 05-12-2007   #9
I'm with Jon.....I humbly suggest checking the trans fluid level.
However mine whines in reverse.....and I'm not even married but I got me a G/F.
I think any manual trans whines in reverse because of the straight cut gears. I do not believe I've ever heard any whinning in neutral but it does make some noise in neutral because the gears in 1 thru 4 are straight cut...sometimes if you listen closely you will hear the noise from the T/O bering and if you have the Pilot bearing in stead of the pilot bushing you will hear some noise...but usually it's not a whine, not like the whine from reversing.
Old 05-12-2007   #10
Peaven
Peaven's Avatar
This one makes all kinds of different noises when you put her in reverse and start backing her up...http://www.zr1netregistry.com/forum/...ead.php?t=3317
Warning: Donsters and others offended by "bringing up the rear", don't click der linker.
Peaven is offline   Reply With Quote
