Old 01-10-2009   #1
Bob G
Default Brakes
I am thinking of buying Wilwood SL6R Front brake kit. superlite 6 piston billet calipers ,Alum. Hats with 13 in. rotors does any one have this set up on there car? How do you like Them? How Good Are They?
Thanks Bob G.
Bob G is offline   Reply With Quote
Old 01-10-2009   #2
Zr1 Destroyer
Zr1 Destroyer's Avatar
Default Re: Brakes
They work nice and I get plenty of complimants on them! A quility upgrade for sure, but I have to run a 3/8" spacer when I bolt up the sixteens for the track.
Zr1 Destroyer is offline   Reply With Quote
Old 01-10-2009   #3
Bob G
Default Re: Brakes
Do You Have Any Pics what Color are your Calipers ??
Bob
Old 01-10-2009   #4
Default Re: Brakes
Thanks Bob G.
That's a great brake upgrade....
I like the C6 brake upgrade and you can have it done right for "cheap".
Powdercoat them and get the brackets from Jeff F.
Old 01-10-2009   #5
ZR1Vette
ZR1Vette's Avatar
Default Re: Brakes
Just in case anyone wants to see a Z51 brake set on a C6 with powder coat calipers/brackets/pad backing plates (which is what you can do if you want for a ZR-1) here is my set up on my C6>> NOTE: I am a 'contrarian' and decided on satin black finish instead the more common often used red or yellow or blue..but all is matter of subjective taste
Old 01-10-2009   #6
RICKYRJ1
RICKYRJ1's Avatar
Default Re: Brakes
I have the C6 Z51 brake set-up on my 95, picked it up from Jeff F. Red PC cals. w/Baer 2 peice rotors. Works great and looks good doing it.
Old 01-10-2009   #7
USAFPILOT
USAFPILOT's Avatar
Default Re: Brakes
Will C6 Z51 brakes fit under the stock A-Molds
Old 01-10-2009   #8
Default Re: Brakes
Yes 100%
EDIT! Thanks Jeff, didn't notice the Z51! Stock C5 / C6 no problemo
Old 01-10-2009   #9
Jeffvette
Default Re: Brakes
No.
The C6 Z51 uses a 13.4" rotor. You can get it inside the barrel, but you leave no margin for error. No wheel weights, no caliper flex, no debris and no room for heat ventilation.
You can use the C6 caliper with a "base" C6 rotor or a C5 rotor.
Old 01-10-2009   #10
TFENT
Default Re: Brakes
Originally Posted by Jeffvette View Post
No.
Jeff:
what are the base C6 and C5 rotor dimensions? Is there a write up on what brake upgrades can be done and a parts list? What about rear upgrades, other then to a BBK?
TFENT is offline   Reply With Quote
