Old 09-25-2010   #1
MikeG
MikeG's Avatar
Default Headlights-no light
I am having some issues with my headlights (91 #135). When I turn the headlights on they flip over with no problem - they just don't light up.
I've pulled both lights - they both light up when jumped directly from the battery. All other lights are working OK - just the headlights. Checked power to headlights - OK there too.
HELP! I'm in the "dark"!
MikeG is offline   Reply With Quote
Old 09-25-2010   #2
BOB HDZ
BOB HDZ's Avatar
Default Re: Headlights-no light
did you check the ground?
BOB HDZ is offline   Reply With Quote
Old 09-30-2010   #3
MikeG
MikeG's Avatar
ground is good.
Correction to problem - no power at the headlight - ALL other lights working without any problem
Old 09-30-2010   #4
A1990
A1990's Avatar
Mike, my headlights at one point did just the opposite of yours. They would light up but would not flip over. With power directly to the lights the worked perfectly. It ended up being a relay that is behind the radio.
Dennis Fierstein
90 ZR-1 #2562 Atomic-Z
ZR-1 Net Registry Treasurer
Old 09-30-2010   #5
MikeG
MikeG's Avatar
Thanks for info - how hard is it to pull the radio?
Old 09-30-2010   #6
gbrtng
gbrtng's Avatar
Mike, your 91 does not have a relay for the headlights, it's for the fog lights - I'm looking at FSM pages 8A-100-1 and -2.
Do either low or high beams light? Does the high beam indicator in the cluster light?
Old 09-30-2010   #7
MikeG
MikeG's Avatar
Thanks for info - to your questions - Yes.
All light work when switch is turned to full on position - parking and tail lights. Running light come on when button pressed. Headlight work with jumper wires directly to bulbs.
I'm on my way to a friends house, with FSM, to check system out - he's electrical capable, I'm just down right dangerious with sparks!
Old 10-01-2010   #8
MikeG
MikeG's Avatar
Lights are working! With just a flix of a switch (dimmer switch on turn signal lever) all is well! I knew I hated electricy way back in Auto Mechanics 101 in high school! I wish all the repairs where this easy and cheap (ZERO $$$$)!
Old 10-01-2010   #9
gbrtng
gbrtng's Avatar
Mike, you might want buy a replacement dimmer switch for the day it fails completely.
It's only a matter of time ...
Old 10-02-2010   #10
MikeG
MikeG's Avatar
Thanks for the tip.
Do you have a recommendation for a source?
