Old 07-07-2011   #1
Default Thermostat question
I am getting ready to flush my cooling system and will be going to 180 thermostat.
Question is, is there a gasket for this? Or is it just high temp sealant between the housing and the thermostat? It's been a while and can't remember.
Thanks.
Old 07-07-2011   #2
HAWAIIZR-1's Avatar
Default Re: Thermostat question
Hey Yun,
There is a seal for the thermostat housing. I don't recall using any sealant, just the seal.
Part number: 10226107
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 07-07-2011   #3
Thanks, Craig.
Old 07-07-2011   #4
sammy
the only seal is the rubber gasket that goes around the thermastat. that seals the whole deal
Old 07-07-2011   #5
Daniel_Mc
Daniel_Mc's Avatar
sammy
Sammy's right. Not hard to do at all. Jerry suggested drilling some holes in the thermostat to help the flow of coolant; I did this but haven?t gotten the car back together yet. I?m hoping I drilled them large enough.
Daniel
Old 07-07-2011   #6
bdw18_123
Where exactly do you drill these holes in the thermostat?
Old 07-07-2011   #7
make sure it's put in the correct way...i went through three rads before the idiots at tom henry chevy listened to me
Old 07-08-2011   #8
Daniel_Mc
Daniel_Mc's Avatar
bdw18_123,
I didn't take a picture of the one I did but here is a google search of it.
But when I did the search I ran across this over on the mustang forums:
I am now considering just putting a 180 in with the Ron Davis and being done with it.
Daniel
Old 07-08-2011   #9
sammy
what i did was drill 2 3/32 hole 180 deg apart and install it so one was on the bottem and one on the top . it takes about 10 minutes longer in the winter to get to temp. i found out that 3 1/8 holes were to much for my cars ,causing them to run too cool . i try to have them run as close to 180 as i can .also if they run cooler than 176 the car doesnt go into the learn sec .of the computor .which doesnt effect full throttle but can effect daily driving .
Old 07-08-2011   #10
To drill or not to drill - that is the question...
