Old 11-10-2011   #1
bldavis11
Default Removing Cam Cover Bolts
Gentlemen,
I am now officially stuck. How the heck do you get the rear (firewall side) cam cover bolts off? The top two are easy, but the bottom six on each side are out of my league.
What ratchets, adapters, and extensions are you using to get to these bad boys? I'm past the frustrated point!
Ben
bldavis11 is offline   Reply With Quote
Old 11-10-2011   #2
Scrrem
Scrrem's Avatar
Default Re: Removing Cam Cover Bolts
Originally Posted by bldavis11 View Post
Gentlemen,
Ben
Check this thread in the solutions section.
http://www.zr1.net/forum/showthread.php?p=84245
On the drivers side, it will involve removing the brake booster or undoing the motor mount and jacking up the left side of the motor.
On the passenger side you will need to disasemble the evaporator box to get to the back bolts, not too tough, be careful not to damage the evaporator.
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 11-10-2011   #3
bldavis11
Thanks Rich.
Any idea how to get at the bolts to begin with?!? I can't even fit my socket into the bolt head, much less attach a ratchet of any flavor. Are you using an allen wrench L-shaped torx?
Old 11-10-2011   #4
rhipsher
rhipsher's Avatar
As was mentioned you will have to remove the brake booster or unbolt the motor mount and jack that side up to reach them. Get an impact driver also. The torx pattern can strip very easily if your not careful. An impact driver will get them out stripped or not.
Old 11-10-2011   #5
bldavis11
Roger... off comes the brake booster. What about the passenger side?
Old 11-10-2011   #6
You need to disassemble the Evaporator box, also referred to as the Suit case. Recommend changing to stainless hardware at this time as well
http://www.ebay.com/itm/CORVETTE-ZR-...sories&vxp=mtr
Old 11-10-2011   #7
HAWAIIZR-1's Avatar
You don't want to remove the booster unless you plan to replace it; it will really have you cursing and you will be a certified contortionist. Ask me how I know? I recommend as suggested to jack up the motor on that side.
You will also want to invest in a new, high quality torx bit socket. If you strip a head of the bolt you will really have some regrets. They are really tough if the first time being removed.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 11-10-2011   #8
Gunny
Gunny's Avatar
Trust me on this ...
George
George Jones
Founding Member #14
www.zrwon.com
Gunny is offline   Reply With Quote
Old 11-11-2011   #9
Lemme axe a dumb question...
Won't we be twisting the C-beam when we jack one side of the motor up? Does the motor actually lean to the opposite side, or are you (in fact) just lifting the motor up? I'm sure the C-beam has some elasticity, but just curious to know what if any precautions are taken - or even necessary - when Uz guyz are jacking one side or another to twist the motor.
P.
Old 11-11-2011   #10
Scrrem
Scrrem's Avatar
Man, I am getting ready to pull my cam covers for refinishing. You guys really got me worried about this job. Is it really that bad getting these bolts out?
Rich
Ron Davis Radiator
