Old 05-06-2012   #1
Hoekie
Default What size circlip on DRM coil over shocks?
I have stripped my one shock to be able to fit the FX3 motor. I then found that the circlip in the shock body had broken, can someone maybe tell me the correct size of the circlip?
Hoekie is offline   Reply With Quote
Old 05-07-2012   #2
Default Re: What size circlip on DRM coil over shocks?
http://captainzcnc.com/ try these guys as they may be able to assist you with this situation.
Old 05-07-2012   #3
Hoekie
Thanks for the help Tom but what Im actually looking for is the snap ring that supports the bottom of the spring support (the threaded section and nut) on to the shock.
I did receive a note from DRM today to say that they are moving but that he will keep an eye out for some but that they are not easy to find.
