Old 09-24-2012   #1
Default Z06 Brakes getting ready for install
Getting adapter today so the Brembos will be going to their new home soon. The Z06 rotor is clearly "flatter" than the Brembo and that should pull wheels and tires closer to fender well. The Brembos require longer wheel studs so that's being changed too.
Old 09-24-2012   #2
Default Re: Z06 Brakes getting ready for install
Massive stopping distance difference with the 6 pistons....I was reading an article last night on C6 base model vs Z06/ZR1
25-30 ft from 60 and 45ft from 80
Old 09-24-2012   #3
Dom
Those brakes look great! What pads did you decide on?
Old 09-24-2012   #4
Hog
Thats very impressive.
peace
Hog
Old 09-24-2012   #5
Dave,
I'm using the stock GS pads for now. Lots of meat left on those bones.
How do you like the decal?
Lee,
To quote that birther Trump, these brakes are HUGE!
Old 09-24-2012   #6
efnfast
Dominic I was impressed when I picked them up, now they look GREAT. And guys, those things are huge.
Old 09-24-2012   #7
Dave,
Lee,
LOVE the decal!!!
Might want to sell the used padlets and get ceramic.
Those padlets will dirty up your calipers in the first few hours guaranteed.
Performance of the OEM pads in superb though.
As long as you don't mind cleaning the calipers, keep them on
Old 09-25-2012   #8
WJust some camparison of the Z06 and Brembo rotors
Here's the diameter difference
And here is the height difference. Its about 1.5". Square is resting on top of Brembo rotor hat surface. This is one reason I went to the Z06 rotors. The Brembo is a taller rotor and so pushed out the Z06 wheel further past the fender line. I did a quick test fit and the Z06 wheel will be nearly flush with the fender.
Old 09-25-2012   #9
Corbusa
So I guess you have to use 18 in. rims? I'm just curious on what changes had to be made? Thanks for the write up...
Old 09-25-2012   #10
HAWAIIZR-1's Avatar
All I can say is "WOW"!!
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
