Hi to all ,
Im going to eliminate secondarries with Haibeck prom - got vacum hadecke with this nassesary sistem....everything will go out ![]() Will cruise control - tempomat , afer that still working? Thanks fo repy. Jano |
![]() ![]() Join Date: Feb 2010
I doubt that you'll ever regret "ripping out" the secondaries.
I'm sure someone will answer your question shortly.
1988 KOH Prototype EX5023 sold 1990 ZR-1 #444 Convertible 1990 ZR-1 Black #966 1991 ZR-1 Quazar Blue #296 1957 Duntov SS Project Last edited by Blue Flame Restorations; 03-26-2013 at 04:02 PM. |
#3 | |
![]() Join Date: Nov 2007
Everything in PINK comes out. As you can see, the vacuum port on the right side of the plenum supplies vacuum for the cruise and everything else. ![]() Unless you have a "kit", you'll need some gaskets and some freeze plugs. I would assume Marc is going to round those up as a package and send it along with the prom, yes? If NO, then be sure to ask him for them, or PM me and we'll get it handled. Jerry...are you reading this? You know the gaskets he'll need, and also the freeze plugs (Dorman 555s, as I recall?). P. Last edited by Paul Workman; 03-26-2013 at 03:44 PM. |
#4 | |
![]() Join Date: Jan 2009
#5 | ||
See Vacuum Systems (Secondary and Cruize)
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 03-29-2013 at 10:25 AM. |
Woops..... Another KLUDGE!
![]() Join Date: Sep 2012
Let's see. That means our hp per litre actually goes up!
It's not a kludge if it's well documented and supportable. Just a LT4.9
#10 |
