Old 01-01-2007   #1
jonszr1
jonszr1's Avatar
Default Cam timing?
is there a video that shows how to time the cams in our motor>? what special tools are needed and where can one get them. Or is there someone I could pay to set thew cams . I could drive the motor to them ? anyone got any ideas//help? reason replaced head gaskets due to orange junk.
Old 01-02-2007   #2
guinnessdood
guinnessdood's Avatar
Default Re: Cam timing?
I believe Marc Haibeck made such a video. Give him a shout! www.zr1specialist.com
guinnessdood is offline   Reply With Quote
Old 01-02-2007   #3
jonszr1
jonszr1's Avatar
thanx ully i give hima try
Old 01-02-2007   #4
guinnessdood
Here's the actual article that he wrote for the cam timing....from his website...
http://www.zr1specialist.com/HAT%20W..._camshafts.htm
You will definitely find your 0.1 horsepower and then some by doing the cam timing...you need some special tools and quite a bit of patience...
Old 01-02-2007   #5
1990 quasar blue
I think I would have had Corey do it while it was there. That, and port the heads while he was at it. 430+ then!!!!!!! Hell, maybe 440 with your numbers.
Old 01-02-2007   #6
guinnessdood
I forgot that Milstead did a write up on timing the cams too...
http://www.zr1netregistry.com/cam.htm
Old 01-02-2007   #7
jonszr1
jonszr1's Avatar
Guys the black car that I took to Coreys Is doing fine . The head gasket problem is with my red 90. SO I was going to do a 368 with it but Corey is backed up with the new shop so I thought I would put the head gasket in it and ddrive it till corey was ready. Ya know Its really hard on one to own 2 zr1s
Old 01-04-2007   #8
1990 quasar blue
My mistake. I would send Jeffvette a pm. You could probably work something out with him.
Old 01-04-2007   #9
RedZR
RedZR's Avatar
Any idea what caused the head gasket failure? Were you using Dexcool or something?
RedZR is offline   Reply With Quote
Old 01-06-2007   #10
jonszr1
jonszr1's Avatar
I think previous owner had dexcool in her. the motor dynod decent 347rwhpA157k miles with borla ex and z-industries chip . So decided to pull the motor and just replace both head gaskets . one ? how much is it to get the heads ported? and who. Coreys busier than hell who could I send the heads to that would do a good job. plus who has tensioners?
