i plan on taking the 90 out for a track day at road atlanta.
anyone have a suggestion for an aggressive street / track alignment? Last edited by henryr; 02-06-2017 at 01:36 PM. |
never mind found some links in searches
there's also a place in the owners kit that tells you the settings
![]() Join Date: Sep 2008
danka....
what about lowering this thing a bit ? |
![]() Join Date: Jan 2015
Are you a member of the ZR-1 Registry? If yes, there is a good article in the recent quarterly issue in the Members Only section:
http://www.zr1netregistry.com/Member...ewsletter.aspx I bought the commonly available kit with the longer bolts that allow you to lower the rear (my front is low enough so I left it as is). When are you going to Road Atlanta? Last edited by RussMcB; 02-07-2017 at 09:05 AM. |
i am not but that is on my list
chin has two upcoming events end of Feb and in March |
![]() Join Date: Feb 2011
I would suggest lowering the fronts with coil overs. There aren't very many unmolested ZR-1 front springs left. Don't cut the rubber bushing off of yours to find out you don't like how low it rides or how much softer the preload on the spring gets.
The lowering bolts on the rear are super easy and a half hour job to swap back. |
