Looking for any info on removing engine/transmission from 1990 ZR-1. Things to look out for, hints to make things easier, etc. What has to be removed prior, etc.
thanks. Last edited by ZBrink; 01-26-2025 at 12:42 AM. |
Jeffette described it perfectly and simply......
1) Remove trans 2) Remove exhaust manifolds 3) Remove plenum and inj housings 4) Undo all wiring connections to the motor 5) Undo oil cooler and coolant lines 6) Remove power steering bolts (let unit dangle) 7) Remove ac compressor bolts (let unit dangle) 8) Lift motor Lifting The LT5 ENGINE REMOVAL AND INSTALLATION Jacking engine TIPS Engine removal sequence pictures Engine Installation Engine removal Engine mounts Replacing motor mount covers First engine pull Engine Removal suggestions
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 05-20-2017 at 05:24 PM. |
