I am looking for a part number for a coolant temp sensor for a 91 ZR1 . I am not sure if the part is car specific and there a lot of them out there . I prefer a GM part .
Reason being I have had issues in the past with some non GM parts in other corvettes not reading correctly and causing problems during reprogramming. |
![]() Join Date: May 2010
A good source is Jerry’s gaskets. It depends on which sensor. http://www.jerrysgaskets.com/search....erature+sensor Sent from my iPhone using ZR-1 Net Registry
Craig "ZR-1 NO KA 'OI" "ZR-1 ICHIBAN" 1995 #228 Black/Black with Dunn Heads ZR-1 owner since September 2003 ZR-1 Net Registry Founding Member #0074 NCM Lifetime Member #2048 ![]() Last edited by HAWAIIZR-1; 06-29-2018 at 05:50 PM. |
There are 2 that mount inside the left Injector Housing. One is for the gages the other is for the ECM. The original AC/Delco part numbers were 213-310 for the gages and 213-80 for the ecm.
H ![]() |
Thankyou !
