Old 03-02-2021   #1
rush91
Default No start
I went to go start my Beast and this happened..... I take the battery out and bring it inside the house. So i put the battery back in, all connections tight. I turn the key and hear everything buzz and make the noises we know... i turn the key to start it and everything goes black. No dash lights, no interior lights.... Battery is fully charged. I disconnect the cables and reconnect. Go back in to start, i have dash lights, good voltage. Go to crank and goes black again like the battery is dead. WTF is going on???
Old 03-02-2021   #2
Default Re: No start
Which brand battery and how old?
Old 03-02-2021   #3
rush91
Its a duralast gold... A year or 2 old. I started it a month ago no issues at all.
Old 03-02-2021   #4
indy91zr1
Sounds like a bad battery or ground issue.
indy91zr1 is offline   Reply With Quote
Old 03-03-2021   #5
lfalzarano
The LT5 needs min of 690 CCA. After 24 months a battery may not be able to provide that power.
Old 03-03-2021   #6
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
Have the battery load tested at the parts store.
Save your time and start with that.
Next inspect your cables. Focus on the terminal bolts and the mating surfaces.
Those are the most logical targets.
Once you know you have proper voltage, then we can continue the hunt if needed.
Marty
Old 03-03-2021   #7
rush91
I will take the battery back to Autozone and have them test it today. Thanks for the replies fellas.
Old 03-03-2021   #8
rush91
Took the battery back to Autozone... They testedand it was half dead. So they gave me a new battery, no questions asked. Mine was out of warranty by a year and a half and they insisted on replacing it.... New battery fired her right up!! That was such a cool thing for them to do. And thanks everyone for the replies
Old 03-04-2021   #9
Great news and good for them. Now get out there and drive it!--Bob
WARP TEN is online now   Reply With Quote
Old 03-05-2021   #10
rush91
That's the plan!! Well, after I go get my tags renewed today ( $150 bucks, thanks Illinois)
