Old 08-24-2024   #1
chesnut
Default Body Question - Are Rocker Panels same as regular 1992 C4?
Are rocker panels same as a regular C4 1992 Corvette?
My 1992 passenger side rocker panel was damaged when a tire blew on a semi trailer.
Thanks in advance.
Gary
chesnut is offline   Reply With Quote
Old 08-24-2024   #2
Default Re: Body Question - Are Rocker Panels same as regular 1992 C4?
No ZR-1 only. You can use any off a 90-95. The common C4 has flat rockers ZR-1 rockers have a curve to them..
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
We Gone is online now   Reply With Quote
Old 08-24-2024   #3
tf95ZR1
tf95ZR1's Avatar
Or you can get a set of Brett Henderson's
49th Street style rocker panels (Blue
Flame Restorations).
1995 ZR-1 #106 Blk/ Blk
Owned by me since 2000.
93K miles, but not on motor :-)
Mods the way I want it,
Not afraid to drive it!
Old 08-25-2024   #4
chesnut
thanks We Gone & tf95ZR1 for the info!
Sent Brett Henderson a PM.
The rocker panel is cracked and also broke the hanger bracket end that the wheel well bolts go through.
Question - is the body panel that's right below the hood, infront of the door & above the rocker panel for a ZR1 the same on a regular 92 C4 ?
Appreciate your help. Thanks,
Gary
Old 08-25-2024   #5
tf95ZR1
tf95ZR1's Avatar
BTW the 49th St are NOT stock in appearance
and need to be painted.
T
Old 08-25-2024   #6
Corvettes White
Gary
Yes, gill panel is the same.
George
