Old 02-01-2009   #1
Default Code 64
Is Code 64 a lean right bank?
This is on a 1990.
Old 02-01-2009   #2
Default Re: Code 64
Looks to me like a bad O2 or bad ground on the O2, does that sound correct?
Old 02-01-2009   #3
Default Re: Code 64
Code 64 is a Lean O2 sensor reading. What was happening when the code set? The ECM was seeing a too low O2 sensor reading for at least 2 sec.
I would change the O2 sensors anyway but wouldn't count on the fact that its a defective O2 sensor.
Old 02-01-2009   #4
Default Re: Code 64
Went on while cruising.....not hard accel or anything. Car ran fine.
Old 02-01-2009   #5
Default Re: Code 64
Pull the battery, see if you get code again.
Old 02-02-2009   #6
Default Re: Code 64
My 95 LT1 Vette went thru 4 sensors - all failed resulting in a "lean" code.
My AutoXRay scanner sorted it out very quickly. You can get a bird's eye view of the cross counts and the range averages for both sides. It's available, if you want to use it.
P.
