Old 11-07-2009   #1
salvatore1
Default What size allen wrench do I need for the Transmission oil fill/add bolts?
...also what fluid would be a acceptable other then that BMW stuff I keep hearing about.
Thanks in advance..........
salvatore1 is offline   Reply With Quote
Old 11-07-2009   #2
Jagdpanzer
Jagdpanzer's Avatar
Default Re: What size allen wrench do I need for the Transmission oil fill/add bolts?
17mm
Old 11-07-2009   #3
salvatore1
17mm
Ok thanks!!!
Old 11-07-2009   #4
flyin ryan
flyin ryan's Avatar
Make sure you put good pressure on the 17mm socket when loosening, it's not a very deep allen head plug.
Old 11-09-2009   #5
Jim Nolan
The cheapest and easiest way to go is to buy a 17mm hex key cut an inch and a half off the end and use 17mm socket and probably a breaker bar if it has not been off before.
Old 11-09-2009   #6
Jagdpanzer
Jagdpanzer's Avatar
Sears has a short arm 17mm allen wrench for about 9$ that works fine with a cheater.
http://www.sears.com/shc/s/p_10153_1...rd=17+mm+allen
Old 01-05-2010   #7
So...what transmission oil do you use and what differential oil do you use since we are talking oil
Old 01-05-2010   #8
32valvZ
32valvZ's Avatar
I used the BMW oil in the tranny and Royal Purple in the rear diff.
Old 01-05-2010   #9
Pete
Pete's Avatar
Amsoil has replacement trans fluid and diff fluid.
www.amsoil.com
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 01-05-2010   #10
flyin ryan
flyin ryan's Avatar
BMW TWS & in the Diff. use GM's new(er) tricky stuff...can't think of the name of it off the top of my head right now...?
