Old 03-22-2010   #1
jrd1990zr1
jrd1990zr1's Avatar
Default Coolant
Pulled the radiator, flushed out and flushed out the garbage from between the fins. New hoses so I am wondering what should I use for coolant.
I see an older post about "Dexcool".
What is the best coolant to put back in a 1990?
Your thoughts are appreciated.
Old 03-22-2010   #2
xlr8nflorida
xlr8nflorida's Avatar
Default Re: Coolant
I use NAPA, it has the silicates (says it on the bottle) and meets the 1825-M GM spec. It's green in color and inexpensive.
Your main concern is that you want ethylene glycol with silicates and it must meet 1825-M GM Spec.
GM part # 12378560 (expensive) and Original Zerex are other options.
DO NOT USE DEXCOOL WHICH CAN BE ANY COLOR BUT IT IS TYPICALLY ORANGE OR RED.
Good Luck!
Old 03-22-2010   #3
jonszr1
jonszr1's Avatar
Default Re: Coolant
i also use the napa stuff .price is right .stuff from the dealer is 26 per gallon
Old 03-23-2010   #4
1990 415
Default Re: Coolant
This must be a typo : 26 (dollars) per gallon?
1990 415 is offline   Reply With Quote
Old 03-23-2010   #5
jonszr1
jonszr1's Avatar
Default Re: Coolant
no not a typo the last time i bought from bud eyre chev i paid 52 dollars plus tax for 2 gallons of gm 1825. so with ca. tax it came to roughly 57 dollars .it is the 100% anti freeze deal
Old 03-23-2010   #6
jonszr1
jonszr1's Avatar
Default Re: Coolant
the napa stuff was 14.95 per gallon of the same stuff.
Old 03-23-2010   #7
xlr8nflorida
Default Re: Coolant
I think I paid under $10.00 for the Napa stuff.
Just FYI, NAPA has NAPA Gold Filters 40% off this month. Not sure if its my area or National
http://ecatalograck.genpt.com/flyer/...eId=7.0.2.0001
Old 03-23-2010   #8
Default Re: Coolant
The standard green stuff. Dont overthink this one.
Old 03-23-2010   #9
Default Re: Coolant
Old 03-23-2010   #10
jrd1990zr1
jrd1990zr1's Avatar
Default Re: Coolant
Stopped by Advance Auto on the way home. Prestone and Advance's coolant doesn't contain silicates. Peak antifreeze does. $12.50 a gallon.
The key is to get the stuff that is the old formula. Thanks for the advice everyone!!!
