The best product is the 3m perfect it #3 cleaner clay part#38070.
For best results get some good quailty car wash/water and use to keep the clay wet. Do this in the shade as well, use it on your glass also. It will shine like a new diamond. As you clean the car look at the clay for dirt and make sure you flip it over from time to time. The clay will conform to the angles you rub. When done get yourself some good polish not wax. I use 3m perfect it polish or liquid glass it has no wax. My car shines like a gem. Try it you will like it. Do this every 3 to 6 months. Your paint will love it and so will you. Let me know your results. Ray ![]() Last edited by BBBAD94ZR1; 03-02-2006 at 12:13 PM. |
![]() Join Date: Jul 2005
I agree with you on use of Liquid Glass. I have been using it on my cars for over 20 years and have stuck with it as I have always received compliments on my cars' finishes.
Over the years I have tried other products from time to time, but I have always come back to Liquid Glass. ![]() |
Is Liquid Glass better than Zaino that I have been hearing about?
![]() Thanks, Craig |
#4 | |
![]() Join Date: Dec 2003
Liquid Glass is a synthetic polymer like Zaino only less expensive, and readily available. I have never compared the two, but if you were to prep the paint the same way before hand, you should be happy with either one. ![]() |
Z Factor,
Thanks for the info. Hopefully someday I will have the opportunity to see a Zaino maintained car to make a determination of how great it is. I was hesitant due to reading about putting many applications and I'm not into doing it more than twice in one session. I remember using Liquid Glass way, way back and I don't remember it leaving a lasting impression on me. I forget what I am using now but it is a German product and I really like it but not sure if my paint could look better. |
I agree with Z factor however I do not use wax. Never have. I do car resto's and wax after a period of 10 years causes paint issues, peeling,crows feet etc. Paint expands and contacts with heat, cold and temp changes. Some waxes inhibit this causing issues. This is also true with fiberglass. It is cured but has the same tendencies Talk to any old timer who has an orig. 60 or 70's car with orig. paint and 95% of the will back this up NO WAX. I also feel this is why there are delamination issues the our winsheilds. Whatever adhesive was used is failing due to temp/climate/uv rays.
Just my 2 cents. RAY |
#7 | |
#8 | |
Wax expands and contracts with heat too. As does just about any solid or liquid known to man. And wax would have to have one heck of a strong bond to actually hold together under expanding paint and crack it. You'd mentioned once about "breathing". Rather than argue that, I'd point out that an acrylic product like Liquid Glass, or a polymer like Zaino, would also inhibit this "breathing" as they seal the paint. The whole point of a protective product is to seal the paint. If the paint is protected from oxygen in the air, it will have a much harder time oxidizing. And waxes or sealants help keep environmental contaminents off the paint, at least for a short time until you remove the contaminent. Some also help to reduce the UV that hits the paint. I would ask what evidence you found that the peelign paint, crows feet, etc were caused by wax, though? How do you know the crows feet weren't from too thick a film of paint, too little flex agent, a body panel that flexs too much, etc? Or the peeling from improper prep? How can you look at failed 10 year old paint and conclusively say what caused it to fail? You are certainly entitled to your opinion, but there are plenty of people (more than 5% of "old timers") who have used waxes for years with no problems. Considering there are several big companies that have made wax products for over 50 years, I'd guess that they'd be out of business if 95% of the detailing population from 1960 and beyond feels they will ruin paint. |
#9 | |
With Liquid Glass vs Zaino, though, one difference I'd point out is I *believe* Liquid Glass has some cleaning ability to it, which would make it better to use on a car that isn't prepped as well. |
#10 |
To each their own, but I would just point out there are people who've used wax for years and never had problems.
Wax expands and contracts with heat too. As does just about any solid or liquid known to man. And wax would have to have one heck of a strong bond to actually hold together under expanding paint and crack it. You'd mentioned once about "breathing". Rather than argue that, I'd point out that an acrylic product like Liquid Glass, or a polymer like Zaino, would also inhibit this "breathing" as they seal the paint. The whole point of a protective product is to seal the paint. If the paint is protected from oxygen in the air, it will have a much harder time oxidizing. And waxes or sealants help keep environmental contaminents off the paint, at least for a short time until you remove the contaminent. Some also help to reduce the UV that hits the paint. I would ask what evidence you found that the peelign paint, crows feet, etc were caused by wax, though? How do you know the crows feet weren't from too thick a film of paint, too little flex agent, a body panel that flexs too much, etc? Or the peeling from improper prep? How can you look at failed 10 year old paint and conclusively say what caused it to fail? You are certainly entitled to your opinion, but there are plenty of people (more than 5% of "old timers") who have used waxes for years with no problems. Considering there are several big companies that have made wax products for over 50 years, I'd guess that they'd be out of business if 95% of the detailing population from 1960 and beyond feels they will ruin paint.__________________ 1990 Corvette ZR-1 #2517 Hear it! Well Im going to close with this. USE WAX! Pleace......... ![]() Ray |
