After fighting with this for 2.5 hours and spending countless hours searching on the web, I am hoping that one of you guys can help solve this problem I'm having.
![]() I am trying to adjust the passenger side window so it will seal. I have the tip in and stops adjusted correctly so the window is sitting tight along the roof and A-pillar weather stripping. But for the life of me, I can not get the B-pillar to seal. The gap is large enough that I can easily see that the window is not touching the weather stripping. The problem is, I don't see any adjustments that allow for the window to come in, even the striker and latch aren't adjustable. Am I missing something guys?? ![]() I have tried using my FSM for adjustment tips, but it isn't much help. Any help from the wealth of experience on here would be greatly appreciated!! I have attached a photo of the window bolts for reference if someone needs it. ![]() I'm hoping to have this sealed up for the 6.5 hour road trip this weekend. T Last edited by Alberta_ZR1; 05-17-2011 at 12:54 AM. |
Tyler relax the felt stops. You have to be to far forward against the window. Im amazed the power windows are working
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director ![]() 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 05-17-2011 at 02:13 AM. |
![]() Join Date: Feb 2006
It looks like you are going have to adjust the glass backward - Start by loosening the three studs that attach the window to the lift mechanism.
Have you replaced the B-pillar seal with a non-factory piece?
#4 | |
The drivers door seals up perfectly with the new stripping, but this passenger door definitely is not going as well. Thanks for the suggestion on this. |
Yes the B-pillar was replaced with a non-factory piece, mainly because they don't make the "good" stuff anymore, but the drivers door seals perfectly fine.
I have adjust the window backward, but them I'm too far back from the A-pillar and it doesn't align right. But I will gave the glass an adjustment again and see. |
![]() Join Date: Feb 2009
Tyler,
Post up on your outcome. I just had my windshield replaced and the gasket was non-OEM. On the way down to BG, I had air wistling at the top or side on both sides and leaked water on the drivers side. The glass guy told me an ajustment may be required. I've never done this, but may give it a try. Rich
![]() Join Date: Aug 2006
Like Goldcyclone said, loosen and relax the felt window stop for the rear of the window.
Then, along the bottom of the door(facing the ground), there are 2 bolts that hold the bottom of the window regulator. Loosen the bolt and move out or in as needed. As you move the bottom of the regulator you will notice the top of the window tip in and out. I hope this helps. |
#8 | |
![]() Rich
Yes.... And no problem. Lets us know if that solves the problem
#10 | |
Sorry for the confusion. I tried an aftermarket B pillar weatherstrip and could not adjust to achieve seal and avaid the window from binding. Ended up replacing with factory piece. They can still be found. ![]() |
