Old 05-31-2011   #1
Default Ported intake
Ported IH, these are stage I and are 36MM at the surface....they progressively move down to 33mm at the bottom of the IH on the primary and on the secondary they are 36MM. The injector bosses have been removed.
Both IHS are done I will do the plenum this week...paint the plenum and IHs
Cost is $450
I can open to 36mm straight through for $700
**All prices are with you giving me your IHs and Plenum in exchange..
**Shipping is extra
If you need them installed and are in driving distance to Chicago, I can put it on for a reasonable price.....gaskets at your cost.
Old 05-31-2011   #2
Default Re: Ported intake
Unported stock: These can neck down to as small as 31mm at the head face
Stage I port same runner: I make sure its a true 33mm at IH to head face on primary
Old 05-31-2011   #3
Stock IH at head mating surface, as noted they can be as small as 31mm and note the large bosses which impede air flow:
These are stage I, I will clean these up even more, I had originally ported this for my car:
Old 05-31-2011   #4
Coolant block offs installed also
Old 05-31-2011   #5
rhipsher
rhipsher's Avatar
That ball gage looks like a moon rock. Lol!
Old 05-31-2011   #6
That is a 35mm foose ball that has been to hell and back...covered in aluminum and WD40
Old 05-31-2011   #7
mike100
^^ I also purchased a foosball when I did mine...it just seems to come up on a google search if you look up '35mm ball'
Old 06-27-2011   #8
Well while I wait for my block work....opened these up more, and started on the plenum......checking interest...they are now 35+ down to the bosses....as big maybe bigger than the ones on my 391rwhp car.
Old 06-28-2011   #9
Paul in VA
Hi:
If I might, I would like to ask some questions... What size are the ports in the head (that the IH bolts to)? Does one also want to match the IH to the Pleneum in order to maintain a constant size? What coolant block offs are installed (0r rather why)? What is the anticipated gain from this porting?
Paul in VA is offline   Reply With Quote
Old 06-28-2011   #10
I really need to get my car ported...just can't afford it now.
the coolant bypass is for the TB, gm put them there to run coolant into the TB to keep the plates from icing up in cold weather...but who drives a zr-1 in cold weather? the advantages are to keep the air cooler into the motor providing (possibly) more power and the ability to pull the plenum without having to dump coolant
